BMR Suspension
11-23-2010, 12:57 PM
BMR Fabrication
Lowering A-arms for the 4th Gen F-Body
Lower the front of your 4th Generation F-body 1” without effecting suspension travel with a set of Lowering A-arms from BMR Fabrication. Based on our well proven traditional A-arm design, these lowering A-arms are constructed from a combination of 1-5/8” and 1-1/4” DOM tubing and feature 3/16” laser cut steel plates and CNC machined ball joint cups. The BMR Lowering A-arms (AA020) utilize a combination of low-deflection, internally fluted polyurethane bushings and Teflon-lined XR series spherical rod ends with stainless spacers. The result is a high quality tubular A-arm that not only reduces weight by 10 lbs. but lowers the vehicle without the typical geometry and alignment concerns. Installation time is only 2-3 hours. Available in black hammertone or red powdercoat.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com (http://www.bmrsuspension.com/), email sales@bmrfabrication.com, or contact them at BMR Fabrication, 12581 US Highway 301 North, Thonotosassa, FL 33592, 813-986-9302, Fax: 813-986-8055.
http://www.bmrsuspension.com/ForumImages/AA020R_med.jpg
