275/40/17, Rear 315/35/17 - 65mm offset
Old 11-24-2010, 09:13 AM
Ape Man's Avatar
Default 275/40/17, Rear 315/35/17 - 65mm offset
Im looking at :
ZR1 replica rims Front 275/40/17, Rear 315/35/17
Sumitomo HTR-Z tires. 95% tread. 65mm off-set. 5 x 4 1/2" bolt pattern. Came off '86 Corvette.
Will I need anything, Ive tried searching, but didnt find 100% answer. I wanna make sure before I buy em. Should they just bolt on?
Old 11-24-2010, 09:51 AM
cemlsx's Avatar
i dont think +65 offset will bolt on without spacers ..
https://ls1tech.com/forums/wheels-ti...must-read.html
Old 11-24-2010, 02:15 PM
Ape Man's Avatar
Just want to make sure being an 11inch rim, 65mm offset with a 315 that if i space them itll stay within fender lip. anybody running this combo?
Old 11-24-2010, 02:40 PM
ScrapinBye's Avatar
If I read this correctly, you said those wheels are a 5 X 4.5" bolt pattern. Ours are 5 X 4.75" bolt pattern (120.65mm). So no they will not work.
Old 11-25-2010, 01:53 PM
VinR1's Avatar
cool... A 'vette w ford bolt pattern
