Need opinion's
Need opinion's
I had a dash plaque made should I place it on the dash by the passenger side or on the main part of the dash right under the DIC Controls Take a look.
I know it blurry but it's the best I could take
youre going to need some thicker double sided tape, because without going out to my car ( its effing freezing out ) i think that spot under the DIC controls has a bit of a curve to it ...
its not that its the best spot, i think its really the only spot unless you put it on the passenger airbag ... which wouldnt be a bad spot either ... because lets face it, shes a garage queen
Will it fit betwen the two left/ right vent adjusters that are located directly above the radio? It might look nice there. Or in the area between the radio and hvac controls. (I like things to be centered! )
2. unless you put it on the passenger airbag . Agreed
2. If I change out the radio to a Nav System I would have to remove it.
hang on ... BRB
yeah, under the DIC controls on the silver part, or on the black plastic next to the ignition under the DIC ... looks to be the best spot ...
Post that pic! I had a factory GXP badge on the passender side of the dash, but it just wasnt strong enough to hold for very long. Hopefully you'll have better luck than I did of getting it to stay!
