97 Lt1 30th Anniversary Edition
OK this is a true 30th anniversary Edition Z28 "z4c" Rare hardtop only 648 were made hardtop in the 30th anniversary edition, 728 in convertable. That means it is white with orange hugger stripes the true anniversary edition, has the matching carpet and its in the headseats. Matching white n orange seats to match jus done 6 months ago. Car was repainted less than a year ago so flawless paint had the stripes painted on instead of the facotry stripe kit which was starting to peel,Had to call GM to get those numbers lol. But this car is not stock far from it. Most the of work was done by Tick Performance out in Mooresville. It is 388 stroked, with Forgered Eagle Crank, SRP Forgered Pistons and Connecting Rods, it is the LT1 Iron block, Joe Stewart in mooresville did the stroker kit on it, ,msd window switch, granatelli fuel pump, csr electric water pump,Ford SV0 30 lbs injectors, Kooks longtube headers, kooks 3.5 y-pipe both cermanic coated, borla stainless steel exhaust with dhm eletric cutout, and also has 2 dhm electric cutouts on the y-pipe as well, GM LT1 Heads and Intake ported n polished, 7.00 hardneded Chromemoly Pushrods, comp 987 valve spring set, comp 987 titanium retainers, comp locks, comp spring seats, pro comp rocker arm set, ati super damper, tpis 58 mm throttle body, Gm extreme duty timing chain, Comp cam 230/236 cam almost .600 lift, also has a 100 shot of wet shot on it WOT activated with purge n bottle heater,has T-56 with tick performance level 2 build kit in it, spec stage 3 clutch,spec flywheel, spohn subframe connectors, spohn lower control arms adjustable, spohn panhard bar adjustable, spohn adjustable torque arm-longtube headers/y-pipe with front&rear safety loops,eibach pro lowering springs drop it lil over a inch, koni sport shocks front and rear, NITTO NT555R DRAG RADIAL : 285/35ZR18 97Y, 18x9.5 Z06 Rims, slp line lock control, Raptor Performance Digital Mini Shift Light with Launch Feature, Has SS Ram Air Hood with ram air kit on it, Moser 9" rear end with 4;11 gears, Detroit trueTrac, 31 spl axles, LCA Relocation brackets, spohn sway bar, 4 channel abs,also have a rollcage for this car never put it in though but it goes with the car, lol. I have all the paperwork and reciepts from all the work done it to, i bought it with 58,000 miles on it all the work was done at 61,000 miles on it it NOW has 80,000 miles on it, everything is basically brand new from engine, tranny, and rearend and chasis n susenspion work done to it, car produces 409 rwhp and 397 rwtq on motor, and 510 rwhp and 537 rwtq on 100 shot of nos, im lookin to sell this because i really want a 03 or 04 cobra, I have more pics if u would like to see these are jus first ones i can find on my computer
randy-336-432-6614 text or call, yahoo- spiderna
