Generation IV External Engine - Chipped LS3 block on ebay
View Full Version : Chipped LS3 block on ebay
LarryYu
11-27-2010, 09:43 PM
Can an engine block as the one advertised below become salvageable?? And if it is salvageable would it cost a lot to fix??
http://cgi.ebay.com/ebaymotors/2010-Camaro-SS-Corvette-6-2L-LS3-Engine-Block-Chipped-_W0QQcmdZViewItemQQhashZitem483da970d3QQitemZ31027 2159955QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccesso ries
t/a98
11-27-2010, 09:51 PM
I think the seller is a sponsor on here. Looks like it would be a good candidate for someone who isn't running a/c.. I just wonder if that one big chip is structural..
sabastian458
11-27-2010, 10:10 PM
doesnt look to bad, but it would have to be checked for other cracks. Looks like maybe it was involved in a collision that hit right there causing the compressor to be ripped off. Im sure if someone had the time and resources, they could TIG those areas up, tap, and helicoil the bolt holes. I would be more concerned with if there are other stress cracks or fissures in other areas on the block from an impact of that caliber.
Jimbo1367
11-28-2010, 12:30 PM
I wouldn't bother personally.
lsxmalibu
11-28-2010, 01:40 PM
look at the block mounting pad, looks like a motor mount hole is cracked also.
chriswtx
11-28-2010, 02:39 PM
yep, lower mount hole is cracked in 2 places.. block is trash..
Luke Skyjacker
11-28-2010, 04:50 PM
i wanna see the car
sixt9er
11-28-2010, 05:27 PM
I was seriously considering this same engine block. I had looked at it several times over. I was also trying to convince myself that it was worth it and it could be repaired. I showed my local machine shop this same Ebay auction pics and he responded, "...it would cost you less to purchase a new block versus me charging you to repair this one..." He did say that it could be repaired though.
SSPerformance
11-28-2010, 05:34 PM
block is junk....
Mighty Whitey
11-28-2010, 07:18 PM
I'd buy it if I was in the market for one.
The a/c mount holes could easily be milled down below the cracks, taking care of that issue, the motor mount hole could be drill oversized (like 3/4") and have a slug welded in place and re drilled/tapped.
On the other hand, if you're not in the position to do these repairs yourself, and would have to farm out the work, it probably would be very costly.
Jimmy P
11-28-2010, 07:21 PM
The current bid is $500..deffinanly not a good deal at all.
Gray86hatch
11-28-2010, 08:18 PM
I have a l92 that just needs a set of caps. $300 is a steel.
Tim
Anthony Williams
11-28-2010, 09:05 PM
Nice boat anchor!
