Warhorse
11-28-2010, 08:44 PM
In HP Tuner software, Is there a way to adjust Knock Learn settings to accelerate the return to high octane table? If so, please explain
LS3 machine
12-12-2010, 06:31 PM
Not exactly what your looking for, but under the spark/retard/knock retard attack, there is a base retard function. The numbers in that table are very aggressive from the factory. They represent how much timing will be reduced for each knock event. Reducing them by half seems to be a reasonable amount, from an experienced tuner that helped me set up my tune.
Tim
LS3 machine
12-12-2010, 07:04 PM
Check this thread:
http://www.ls1tech.com/forums/gen-5-camaro-tuning-diagnostics-dyno-results/1310867-2010-kr-issue-solved.html#post14228948
Try the decay table.... Im new too so not sure what numbers to put in it.
