Tools & Fabrication - question for 4 post lift users
25thhawk
12-01-2010, 11:11 PM
When you lower the lift all the way down, does it go all the way to the floor? I just finished installing a Bendpak in my garage and when fully lowered, the cables are still tight and the rails are 2 inches off the ground. Almost seems like the cables are too short.
gearhead 69
12-01-2010, 11:15 PM
u aught to have some slack under the ramps were the lines run under them i had the same problem with one.just raise it up an u awta see.
25thhawk
12-01-2010, 11:35 PM
not sure that I understand. The cables never lose any tension. There is nothing that runs below the ramps or crossmembers. It all runs inside them and cant get caught. It just seems like the ram is fully extended, but lift doesn't make it to the floor
Competition GT
12-22-2010, 11:04 AM
That doesn't sound right at all. I have 4 bendpak lifts and all of them (including the 4 posts) have slack past even with the ramp on the floor.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
