Trans Fluid Leak
Trans Fluid Leak
I recently noticed some drops in the garage, crawled under the car and found this. Its where the bell housing connects to the back of the motor. Its a pretty slow leak, about a drop a day. Is it some sort of seal, any input or thoughts would be appreciated.
Uploaded with ImageShack.us
My Z is doing the same thing. It's such a slow leak that I don't even have to pay attention to it. I just check the oil every 500 miles or so like I always do and add accordingly. I have to add a quart IF THAT inbetween oil changes. My diff is leaking even slower, and its not even coming from the gasket, i've noticed a little fluid on the u joint but it's a really thin layer, doesn't even drip. I figured that's probably the result of using synthetic fluid when I got the new gears put in.
