Generation IV Internal Engine - going to the junkyard. What motor?
L SS 1
12-02-2010, 08:16 PM
Im looking for a motor to go with the mods in my sig, but may change some. Im thinking lq9 but may be hard to find. lq4 is an option as well. I have'nt really been keeping up with info on the newer motors. Is there a motor that I can just cam and run deep into the 11's in my heavy vert. I want to weight my options of having a reliable motor put together by gm and cost of a hke build. If i find a cheap high milage jy motor Ill re-use my ms4 cam and springs if there good . If i find a low milage one i will buy a new cam.
mahalik
12-07-2010, 08:24 PM
Yeah, im in the SAME situation...
BOBS99SS
12-12-2010, 01:21 PM
Same here,I have called every junk yard in northern ohio and cannot find a lq4,9.I m new to building engines,I have learned a lot about my ls1 but I don't know what would be a good swap to do,I was thinking about buying a new lq9 block from scoogin dickey,and just buying a rotating assembly,any one think this is a good idea,I have a budget of 3 to 4 grand for a block but if I can save money that's always a plus,I would like to reuse my ms4,and stage 1 243s,or should I be looking into a ls2,ls3? I plan to use all my acc. Off the ls1,again if it sounds like I don't know what I'm talking about I don't lol,
BOBS99SS
12-12-2010, 02:00 PM
I like the setup I have now but my motor has 122k on it,which it still runs good but I would like to go with a fresh motor and be done with it,
bozzhawg
12-12-2010, 03:41 PM
car-parts.com
You can find you a
LQ4
LQ9
LY6
for cheap, around $800-$1500 with reasonble mileage.... of course, less mileage, usually more expensive....
They have LS2's,LS3's,L92's but they are going to be a little more......
install the cam, follow proper procedures, assuming you have the know how(ptvc check,spring kit,pushrods,lifters, etc...) yada yada yada.......
drop it in and roll....
If you blow it, which I doubt, you'll only be out of $1500-$2500 vs $8000-$10000.... I will will take my chances, as long as they the junkyards keep filling up with the 6.0's+ etc..... I am not spraying or boost, so a stock bottom end is good for me... Alot of guys over do it and forge everything, but if your not using any power adders or trick stuff, just a N/A setup, a stock bottomend would be fine, but its up to you and your intent....
Now if you want something custom, etc... then look into getting one custom built by said HKE or whoever you chose, but for a budget banger, it can be done..... If you got a more time than money...... But if you got the money, knock yourself out...
Bozz
garygnu
12-12-2010, 04:15 PM
schwanke engines has good price on short blocks,or get a 383 short block from TSP.
redsap05
12-12-2010, 08:30 PM
the best one to find is the l92 out of the 2007 and newer escalade and denali. its basicly a ls3 with a differnt intake manifold.
smok'nZ
12-12-2010, 08:35 PM
id look for a LQ4 or LQ9 for around 1000 complete from intake to pan
BOBS99SS
12-12-2010, 11:15 PM
Bozzhog thanks man ,they had some good deals ,
bozzhawg
12-12-2010, 11:47 PM
:thumb: If you need anymore help just pm me....
Bozz
ponjohn
12-22-2010, 10:42 AM
Is this an iron block?
Jimbo1367
12-24-2010, 08:20 AM
No. Its aluminum just like a LS3. Since its basically is a LS3
87silverbullet
12-24-2010, 08:58 AM
For those of you who still have a cathedral style intake you might want to look into an ls2 since it will work with with everything you have. The lq9 is 10.0 comp. and the lq4 is 9.4 comp. so that is something to think about with the lower compression in your quest for more cubes you are getting less compression.
The l92 and ls3 motors are great but they have a different intake and are dbw throttle body. You will end up needing a cable driven TB. The cranks are 58X tooth and the ls1 ecm is 24x tooth so you will need to convert that too. Also, check out LKQ for motors.
nerisls1z
12-27-2010, 12:42 PM
Well I live in Philly an looked for a motor to swap my old ls1 out which ran 11's an came across a site on ebay not to put another site on here but for $900 bucks with 3 month warranty which i didnt care for anyways I bought a LQ9 out of a 07 ss silverado 35k m complete everything even ecu an free shipping now that was a steal an shipping was quick 2 days right to my door
drgracer392
12-29-2010, 05:32 PM
nerisls1z you have pm.....thanks
ponjohn
01-01-2011, 08:58 PM
Another question.
I'd like to use the L92 heads.
The Lq4 as a shortblock is only 9.4-1. Can an L92 head be milled safely to get the compression to 10.8-11? ( probably not)
If not, then It seems the LY6, L92 or Lq9 is the better option....Yes?
tboysen00
08-29-2011, 06:21 PM
Another question.
^^^I would think you could???? 11.1
Also, all the lq4 motors I can find have over 150,000 miles on them. I would perfer not to tear apart the short block. How many miles are to many if I want to setup a heads/cam + 150 shot?
