what width 19's on t/a
Old 12-02-2010, 10:29 PM
teamfbody's Avatar
Default what width 19's on t/a
I'm about to order some 18/19"dd C6 Z06 wheels from Oe wheels but I need to know what size 19" tire I can fit on the rear of a 2000 Trans Am without it rubbing the rear inner fenders or when I hit a bump I don't want nothing too tall or wide,I also want to know if I will need spacers on the front & rear wheels? Thanx in advance
Old 12-02-2010, 10:52 PM
rabbit320's Avatar
oe wheels should say on their site... i think the rears need spacers but fronts are ok... also depends if you are lowered
Old 12-02-2010, 11:55 PM
teamfbody's Avatar
thanx it has stock suspension
Old 12-03-2010, 01:17 AM
99Bluz28's Avatar
IMO, if you need spacers to make them fit correctly then the offset / backspacing isn't right.
Old 12-03-2010, 12:45 PM
teamfbody's Avatar
99bluz28 I will have to consult with Scott at oe wheels he'll know which size I should get
Old 12-03-2010, 12:50 PM
caramaro's Avatar
12" rears with 5/8 spacer and bfh mostly on passenger side where spare tire is.325/30 are what i'm running,oem 07 z06 tires,,,longer wheel studs as well
Old 12-03-2010, 01:30 PM
99Bluz28's Avatar
You shouldn't have any issues with a 19 x 10.5 w/+50 to +44 offset and a 295/30/19, 305/30/19.
If you want a little more rear sidewall then a 295/35/19.
Old 12-03-2010, 01:37 PM
whtnuklz's Avatar
I have 19 X 10's with 305 30-19's on the rear with strano springs. I have no spacers or any rubbing at all. If you get the offset/backspacing right they will fit fine
