General LSX Automobile Discussion - Air removal: What do I do with this?
Greekey
12-02-2010, 11:01 PM
Guys im taking out the air system in my car. I've cut the hose running to the passenger side header on the left, I've taken off the hose in the center running to the driver header and I've taken off the hose going to the air pump on the right. What do I do with these ports now? Do I just plug the little plastic hose thats going to the top of this thing and call it a day? Or can I just leave the whole thing back there just the way it is?
http://i142.photobucket.com/albums/r108/iraclis/IMG_0523.jpg
PontiacFan
12-03-2010, 09:02 AM
Yes, cap/plug the small line going to it. It doesn't take much to remove it, why would you leave it there after removing everything else?!? If possible, cut it as short as possible & cap it, Or remove it from it's source & plug/cap it.
No 'cutting' necessary when doing this !AIR/!EGR. Simply remove everything as one big assembled package.
Remove the AIR pump from the underside, in front of the front tire.
Edit: I was gonna say, there are numerous threads with more info on the 'how-to' here.
But must have been called away to my work computer, ..., at the other end of my desk, ...
Greekey
12-03-2010, 09:06 AM
Okay, well what about the other small line going to the intake manifold?
Z06 Steve
12-03-2010, 09:55 AM
remove and cap or just plug with a bolt in the rubber vac line end. I just did this.
nemss1
12-03-2010, 11:36 AM
just go ahead and remove everything. put a vacuum cap over the nipple on the back of the intake manifold. no 'cutting' necessary on anything. speed inc and texasautocraft.com make blockoff plates for the manifolds, or you could fab up your own
CJDZ24_Z28
12-04-2010, 07:03 AM
you can block off the intake manifold with a Freeze plug from Pep Boys. Its like $3.00 just remove everything
bayer-z28
12-04-2010, 07:19 AM
^^ I just pulled the line right off the back of the intake and got rid of the T that was there and plugged the HVAC line back into the back of the intake. And the TOP of the intake in the front is the EGR.
Cole Train
12-04-2010, 06:47 PM
Yep cap the line and pull the crap out. Block off plates can be bought or made :D i made mine from steel and some cutting tools for free :D
billscamaros
12-05-2010, 02:06 PM
sorry for the question ...... but what do you plan to gain with this mod?
Greekey
12-05-2010, 02:08 PM
No horsepower gain. Its just to clean up the engine bay and make future installs like changing plugs, etc easier.
Greekey
12-25-2010, 12:37 PM
Guys is this part of the air system also? Part is circled.
http://i142.photobucket.com/albums/r108/iraclis/IMG_0523-1.jpg
Jays_SSZ28
12-25-2010, 01:07 PM
Thats the a.i.r. solenoid. Remove that also.
Wow, Ohio lets you guys do that kinda stuff?
Greekey
12-25-2010, 04:39 PM
Ohio? No emissions here.
Aetos
12-28-2010, 10:48 PM
wait, am I missing something? What small nipples and plugs are you guys talking about?
All I removed from my car was the following(pic taken from the air removal guide):
http://i160.photobucket.com/albums/t164/Freaks-Photos/tutorials/IMG_0807Large.jpg
Did I do something wrong? O.O
Edit: After more searching it seems like 98 and 99 cars differ from the later years?
Jays_SSZ28
12-28-2010, 11:09 PM
The solenoid you have circled above has a vacuum line that comes off it and goes to the back of the intake. You need to take that vacuum line off and plug the nipple.
Jays_SSZ28
12-28-2010, 11:21 PM
Heres the rear view of the engine. The end of that hose with the check valve in it (in your picture also) plugs into a tee in the back. It's not that difficult to remove it and plug it.
http://www.ls1tech.com/forums/attachment.php?attachmentid=271358&stc=1&d=1293600064
