BMR Suspension
12-03-2010, 02:03 PM
BMR Fabrication
Sway Bar End Link Kits for Pontiac G8
Reduce End Link deflection and increase sway bar effectiveness in your Pontiac G8 with heavy duty Sway Bar End Links from BMR Fabrication. Upgrading sway bars on this platform has proven to bend the weak 3/8” diameter OE end links when subjected to aggressive driving techniques. BMR’s front end link is made from heavy duty 7/8” diameter tubing and utilizes high quality spherical rod ends on each end. A BMR End Link Kit (ELK007) will outperform the OE end links in your G8, providing you the stability and control necessary for high performance driving. Front End Links (ELK008) and Rear End Links (ELK006) also sold separately. Front links available in red and black hammertone powdercoat finishes. Installation time for both End Link Kits is only 1.5 hours.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com (http://www.bmrsuspension.com/), email sales@bmrfabrication.com, or contact them at BMR Fabrication, 12581 US Highway 301 North, Thonotosassa, FL 33592, 813-986-9302, Fax: 813-986-8055.
http://www.bmrsuspension.com/ForumImages/ELK004R_MED.jpg
