MS4 plus ?Heads
Old 12-04-2010, 09:54 AM
CNTLSE 1's Avatar
Default MS4 plus ?Heads
I am currently running the MS4 and stage 1 PRC LS6 heads. I think its making decent power considering its on a LS6 intake. I am curious to what other heads guys are running with this cam with good results? I will be upgrading the intake as well and plan to spray it. Just curious as to what on the market is doing good without cutting the pistons. I feel there is a lot left on the table from the heads. Thanks
DJ
Old 12-04-2010, 07:57 PM
Captain Double Post
BOBS99SS's Avatar
I have a ms4 and tsp told me the best heads are the prc 227, that's the head the use on the head/cam stock bottom end record holder,I agree the prc stage1 ls6 heads are pretty good but there are such better heads that are better for the ms4,plus tsp can do a lot of diffrent things like aftermarket castings so you will have clearance,if you thought about changing heads I would buy those ones off ya,I got another motor I need a set of heads for,
Old 12-04-2010, 08:04 PM
Captain Double Post
BOBS99SS's Avatar
Guys make pretty good power on the ls6 intake, if I ever bought a fast it would be a used ported fast 90 set up
Old 12-04-2010, 08:09 PM
Captain Double Post
BOBS99SS's Avatar
I know for sure I'm going with the prc 227s on my ms4 in my camaro,there's some info about them on tsps website,from what I have heard from texas speed they flow better than any head they have ever seen,I can't wait to see what those and the 4.56 gears put down next year
Old 12-04-2010, 09:31 PM
09camaro383's Avatar
I have an ms4 cam 90/90 set up dp 150 shot and I almost sh*t my pants everything I hit the nos its just sick and I don't need to go faster but I wish I had the money to get the prc 227 but 2400 is a big chunk if I ever need to go faster I will just add more nos
Old 12-04-2010, 09:59 PM
CNTLSE 1's Avatar
Thanks guys. That was the head I was thinking. I'm going to do a few more changes before the heads get swapped. they will def get sold when swapped though. Damn things would be lucky to have 1000 miles on em
Old 12-05-2010, 05:06 PM
Captain Double Post
BOBS99SS's Avatar
Well let me know when you do,ill take them bare,send me your asking price bkurtz475@gmail.com,I for sure want them ,would work good on my other motor,yeah the 227s is what I'm gonna run with my ms4,just gets the most out of the cam,
Old 12-05-2010, 11:23 PM
lswon240's Avatar
what numbers are you putting down with that set up? I have a project 240sx with the automatic though thats been forever in the making with a ls1 ms4 cam just bought those heads from tsp and also 1 3/4 headers still need a intake only have the stock one but like i said car still isnt wired just constantly buying parts and scratching my head any input would be nice thanks really interested in numbers
Old 12-06-2010, 09:33 AM
Jon@Texas-Speed's Avatar
Depending on the application, either the 215cc heads or the 227cc heads would work with that camshaft. Both will be a nice improvement over the LS6 heads and with the thicker deck surface on an aftermarket casting, they will help hold the gaskets with the nitrous. Give us a call and we'll run over some things with your combo and make sure we get the right head for what you are looking at doing!
Jon
Old 12-06-2010, 12:47 PM
CNTLSE 1's Avatar
What difference in setup would sway towards one head or the other? I'm terrible at getting people called.
Old 12-07-2010, 12:25 PM
CNTLSE 1's Avatar
Also do you know know guesstimate of what horsepower differnce would be going from LS6 heads and intake to PRC 227's and Fast 92/92?
Old 12-08-2010, 09:11 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
The 215 head has better p/v which helps if your not wanting to cut the pistons. Typically we like to see MS4 owners cut their pistons if they're running the 227 head because of the slightly larger valve.
The great thing about these two cylinder head options is we can get you a nice bump in compression without killing tons of valve drop!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
__________________
Jason
2005 Twin Turbo C6
Old 12-08-2010, 12:42 PM
CNTLSE 1's Avatar
So it is suggested to cut the pistons with the 227? Man I really want to avoid that. I was also told by you guys through PM I should run the 227 due to planning on spraying the car
Old 12-08-2010, 01:18 PM
We can set the heads up to clear with the MS4 and 227cc heads. It just has better PTV with the 215cc heads. Granted, other shops sell setups that run WAY tighter PTV than that combo. It would be better to flycut and mill heads but it isn't a must. If you are looking for an all out combo making max hp, the 227cc heads are the ones to run.
Jon
Quick Reply: MS4 plus ?Heads
