Fuel pump wire question C101
Old 12-05-2010, 02:35 PM
1FSTLS1's Avatar
Default Fuel pump wire question C101
Can I use the relay I allready have wired up in the car from the preveous pump or do I need to use the Green/white wire from C101 fuel pump relay control wire? Will the computer see no fuel pump and not run if I use my existing setup? Thanks
Old 12-05-2010, 04:47 PM
Rick Speed's Avatar
You can use your set up with no issues. The PCM really has no idea what the fuel pumps are doing.
Old 12-05-2010, 05:56 PM
1FSTLS1's Avatar
sweet thanks
