98 Camaro (shift light install) SIGNAL WIRE?
Old 12-05-2010, 07:07 PM
9t8z28's Avatar
Default 98 Camaro (shift light install) SIGNAL WIRE?
I just purchased an Auto Meter shift light with controller. I have searched the forums to see which wire on the PCM I need to tap into to get a signal with no success.
Can anyone tell me which pin and what color wire it is? Also, is it located on the top or bottom of the PCM?
Old 12-06-2010, 08:51 PM
BandDirector Blk98ZM6's Avatar
I've got a Raptor shift light and this is straight from their website:
1998 LS1 5.7L equipped Camaros: tach wire is pin #35 on blue PCM connector 98 Z28/SS Install Guide
If installing the Raptor dual mode shift light, connect the white wire of the shift light to the Vehicle Speed Sensor (Vss) output signal from the PCM red connector (pin #55, dark green wire with white stripe).
Here's a link with pictures:
http://www.raptorperformance.com/Ins...tall_guide.htm
Old 12-06-2010, 09:07 PM
rob69zombie's Avatar
^Yup. Same with Harlan shift lights. For 99-02 it's the number 10 pin.
Old 12-06-2010, 09:34 PM
9t8z28's Avatar
Awesome! Thanks guys
Old 03-12-2012, 01:56 PM
FloridaMax's Avatar
Hey guys whats up? how is it to install a shiftlight on a 2001 3.8 V6 camaro?
what pin is it by a 2001 camaro v6? im from germany i found nothin about this... wanna install my shiftlight this spring.
Quick Reply: 98 Camaro (shift light install) SIGNAL WIRE?
