C105 question pin H
Old 12-06-2010, 10:26 PM
leon phelps's Avatar
Default C105 question pin H
Hello,
I see in some pin listings it is shown as an EGR valve and on others as Air injector reaction solenoid relay output-coil.
The wire is orange.
I am thinking I will not need it, but wanted to make sure I dont take it out for no reason.
Thanks for any help.
Old 12-07-2010, 12:56 AM
N21923's Avatar
Might wanna tell us which harness you're talking about. Vettes were different than Fs, 98 Fs were different than 99-00, and 01-02 were a little different as well.
I'm guessing it's a 00 or earlier since you mentioned EGR valve.
Old 12-07-2010, 04:19 AM
sorry, 2002 f body (firebird)
Old 12-07-2010, 04:56 AM
LS1MCSS's Avatar
C105, pin H, orange wire is 12V, battery voltage according to AllData. Orange wires usually are battery voltage and pink wires are usually switched voltage.
Old 12-07-2010, 08:25 AM
thus why I asked the question. Several of the people who have used the complete harnesses say to not use this. I wanted to double check.
Old 12-09-2010, 09:09 AM
N21923's Avatar
Correct, but AllData also says that it's for circuit # 1440. When you look up that circuit, it's for the Secondary Air Injection solenoind, which the OP won't need, unless he needs an emissions legal car.
Old 12-10-2010, 12:57 PM
LS1MCSS's Avatar
Yep, it powers the secondary air injection solenoid and the air pump relay.
Quick Reply: C105 question pin H
