dual pressure fuel system
I need help/advice regarding my fuel system set-up. I have installed the CTS-V LSA engine into my 68 Camaro then had Rick's tanks make me a tank using the CTS-V fuel pump. Now, I need to finish off the system. I want to duplicate the factory duel pressure system, if possible. Can any one help explain what I need to control fuel pressure like done on the CTS-V or ZR1?
LS1TECH Sponsor
The pumps are pulse width modulated from the factory computer/pump control module. There is dual pumps but not a specific dual pressure setting, such as low/high.
This is a lot of extra expense/equipment to install.
You would be much better off with regular fuel pumps & a simple front mount regulator to control pressure.
