Tools & Fabrication - what wire for stainless to mild steel
ls1curt
12-08-2010, 02:16 PM
Hey guys, im mig welding stainless to mild steel. what wire should i be using for this?
thanks
ls1curt
12-08-2010, 02:19 PM
from what i found, it says i just use stainless wire. i was using ER308L and the welds were not very good
01ssreda4
12-09-2010, 03:30 AM
Try a steel wire. For your average welds its not that crucial.
Fireball
12-09-2010, 07:53 AM
with tig you use a 309 wire...dunno if you can get that for mig or not...
jimmyblue
12-09-2010, 09:17 AM
Maybe you could describe the workpiece and its intended
(ab)use.
Sometimes dissimilar metals are better off brazed.
What does "not good" mean, for the welds? Ugly, brittle,
??? Are you sure this is not settings or shield gas, more
than metal related?
Mr.Nguyen
12-09-2010, 10:03 AM
You still use the same steel wire. It mostly depends on your gas. 75/25 gas mixture will weld it no problem.
01ssreda4
12-09-2010, 10:54 AM
Stainless likes the tri mix :nod:
ls1curt
12-09-2010, 01:18 PM
oh okay, ill just use the wire that i weld steel with. btw, im welding mild steel flanges to stainless headers
01ssreda4
12-09-2010, 01:53 PM
On this application, running the mild steel wire will be perfectly fine. Doesn't mean its the "best" option but it is just header flanges ;)
MikeGyver
12-17-2010, 10:08 PM
309L. That is what it is designed for.
JAX04
02-07-2011, 10:31 AM
im welding what a flex coupling into my crossover, it says its stainless, and my crossover is mild, anything i should be weary of?? just have standard steel wire .035. using a millermatic 211 with autoset, which is amazing my the way, lol
01ssreda4
02-07-2011, 03:47 PM
You can weld stainless with regular steel wire with no sweat. Its not the correct way but will it hold and function in most applications? Absolutely.
cookseyb
02-07-2011, 04:00 PM
Inconel when in doubt.
2000_SS
02-07-2011, 05:21 PM
309L is the correct rod. Your "steel mig wire" I'm guessing is ER70S-6...which does not contain the proper amounts of nickel among other elements to make for a sound weld. It will be brittle and most likely crack after multiple heat cycles, IF you get good fusion to both parts. There's a good chance it will never give you any trouble, but you asked what was right, and 309L is right....i have a 10# box of it I need to burn now that you mention it....
2000_SS
....and a tri-mix gas would help
Slowhawk
02-07-2011, 08:38 PM
I've welded setups like that with steel wire. No failures in 8 years, even welded a few turbo setups like that.
jalper
03-03-2011, 10:30 PM
x2 309L
CAMSTER
03-04-2011, 11:55 AM
Stainless, or a wooden rod...:pimp:
MrDude_1
04-07-2011, 08:36 PM
309 is the proper wire.... its my usual all metal wire. Its harder to find then 308..... that said, I have welded mild steel perfectly fine for non critical apps with common 308 wire.... mostly because it got loaded on accident and I didn't know until the reel went empty.
Midnite Magic
04-07-2011, 08:50 PM
ER70S6, 309 stainless MIG wire will be hard to find
BADD SS
04-08-2011, 08:34 AM
309L
Buy online and it's not too hard to find.....
UMD_Jesse
04-25-2011, 08:04 PM
if its not structural or prone to warping from heat I would say it doesnt matter. Ive welded stainless bungs to stainless pipe using mild steel mig wire and standard 80/20 argon mig gas without any issues. Ive also welded stainless to stainless with stainless wire using mig gas and also havent had issues, but none of this was structural or on exhaust sections to large that heat/cool cycles would cause issues. my 2 cents
SATAN
04-26-2011, 12:08 AM
I'm gonna jump on the band wagon and say 309L as well. Even though I am currently welding 304 to mild using 308... but whatever.
