Cranking noise when i turn on my gxp
Everytime I turn well 8 out of 10 times there's a cranking like sound that comes from the front end somewhere? Any ideas??
Well Guys....That would be called a starter. It assists in turning the flywheel to start the engine
Haha, I love being a smartass, but in reality I have a noise as well. I could post a video and see if it's the same?
Lmfao mister " I love being a smartass" isn't so smart after all haha just kidding, but I'm talkin about when I am driving and I turn it makes a cranking noise.
When I bought the car about 4 months ago, the prev owner said it needed a new power steering pump as it was making a whining noise. Which it was and the dealer even agreed. I had it replaced and the noise was still there. Ended up being a simple idler pulley.
Now, I was told to not completely fill the power steering as it will not allow air to escape the system? It is not FULL but it is full.....if that makes sense?
I will check fluids in the morning
Now with your problem, could it be the CV Joint's?
I had my car at the dealer they did a run thru the car in and out and they said everything seems fine so idk dealers are aholes they won't tell me **** till my warranty is up
Not sure if this is relevant, but when I had my 06 MC SS, it had a snapping or popping noise when you would turn the wheel in parking lots. Took us a while to figure it out, but when we had it up in the air on the drive on lift, one of my guys put his hand on the steering rack while I was turning the wheel. He was able to feel the snapping/popping noise in the rack itself. Thing is it would only do it if the suspension was loaded, like if it were on the pavement.
sounds like the saverage PS system problem or maybe popping of the steering assembly itself.
does it only do it in cold weather or both? had similar problem and ending up being missalignment of a coiple front susp. parts
