upgrade T56 transmission?
Old 12-09-2010, 06:07 PM
98Cammed-outFormula's Avatar
Default upgrade T56 transmission?
is it possible to get a newer transmission from like a 2000+ corvette and bolt right up to what i have now? is it the same bolt pattern? 98 Formula M6 HT
Old 12-09-2010, 06:27 PM
thesource's Avatar
Negative Ghost Rider.........
Old 12-09-2010, 06:34 PM
Nemesis350's Avatar
transmission upgrades for the t56 really aren't as pricey as most think, of course depending on what company and what level you choose. The pricier options usually involve the viper (or better) mainshaft conversion.
I won't specify names, but check out the sponsors here
Old 12-09-2010, 08:01 PM
dgcustomz's Avatar
Call Jason at TDP, He can hook you up with a conversion like that. If you find a vette trans he can convert it it to an f-body and you will have a triple cone trans.
Old 12-09-2010, 08:03 PM
dgcustomz's Avatar
Oh, here is his info....
Texas Drivetrain Performance
Fort Worth, TX 76177
Email: txdrivetrain@hotmail.com
Phone: 817-300-6840
Shop Website: http://www.texasdrivetrainperformance.com/t56.html T56 rebuilds starting at $540!
Clutch Website: www.diamondclutch.com Clutch kits starting at $369!
Old 12-09-2010, 08:06 PM
thesource's Avatar
I believe he asked if it was possible to bolt up a Corvette unit to his F body as a direct fit. The answer to that is NO. It is possible to use the internals of the Corvette with additional parts to build a unit that is a direct fit though.
Old 12-09-2010, 08:08 PM
dgcustomz's Avatar
His question sounded like he found one that might have been cheap so it was the reason he was asking that question. Atleast that's what I got out of it. Gave him an option, no one else did... just sayin....
Old 12-09-2010, 08:59 PM
i havent found one. just thought if it was possible. my transmissions synchros are going out. just main reason i havent taken it the track after an engine rebuild. i thought it would be easier to find a corvette transmission and slide it right in and drive. but im guessing modifications would have to be done in order for it to fit correctly. just a thought that popped in my head. and wanted ppls opinions. and thanks for the info itll come in handy sooner or later.
Old 12-10-2010, 09:42 AM
85MikeTPI's Avatar
As thesource said, it's not a plug and play. If you want some background/info, I wrote-up a DIY conversion by using a factory GTO or SSR mainshaft.
http://www.eecis.udel.edu/~davis/z28..._Fbody_T56.pdf
I believe Jason at TDP will be providing these conversions through his shop shortly also, with a modified SSR mainshaft.
(Jason, can you post up a thread on your mainshaft? I can't seem to find the 9310 mainshaft thread where we were talking about it???)
Old 12-13-2010, 10:58 AM
TDP
TDP's Avatar
You basically have to change the front bearing retainer (front part of the T56) to an f-body style, and change the tailshaft housing to an f-body style. Then you have to use a GTO mainshaft, and an f-body/GTO shift rail. I do this specific conversion for $250 on top of a regular Stage 2 build, which is $680 + 250 = $930 starting price. The only reason I can do it this cheap is that I have several different types of T56s at the moment, so I don't have to go out and pay for the conversion parts (which would be $500-550). Check out Mike's link as it explains all this in detail.
Old 12-13-2010, 11:04 AM
TDP
TDP's Avatar
I'm working on the first one right now. The machinist was sick so it took forever to get the mainshaft back. I was going to have a journal machined at the bottom of the splines so the speedo gear would have its own place to fit. But if a CTSV gear has a nice fit over the splines, then I'll probably just go that route.
Thats weird about that thread disappearing...
I'll take a pic of the shaft at the shop today and post it up tonite in a new thread. If everything goes well, that build will be done today.
Quick Reply: upgrade T56 transmission?
