dual intank pumps-how can i weld a bulkhead fitting on line coming out of tank?
I am slowly building a regal project that i picked up and the questions keep on coming. the car has a dual pump setup in the tank that is hooked up to the stock regal feed and return lines. i would like to run a -8 feed and return line but not sure how to do it. I think i have seen fitting welded onto the lines to attach the braided hose? Can i just put it straight into the top of the pump assembly and hook something up inside? curious as to how to make this work. thanks guys
