T56 And 408 Install Help
Old 12-10-2010, 05:06 PM
DAS1998's Avatar
Default T56 And 408 Install Help
Swapping from 400 to T56 Does anyone know if Clutch and flywheel from ls1 car will work with 6.0 block? Dont know if there is a differnt clutch and flywheel, shims, etc.
Thanks
Old 12-10-2010, 10:48 PM
jmd
jmd's Avatar
As long as the crank face is the same depth from the block face as the LS1 yes. Early 6.0s had a thicker rear flange to mate with the 4L80-E converter (which was originally intended for use w/ 4.3 / 5.7 / BBC depth crank flanges) and then they used a spacer when the cranks went to standard LS_ depth.
