Wiring Harness Question
Old 12-11-2010, 01:59 PM
El S1 Camino's Avatar
Default Wiring Harness Question
I was working on stripping the unneeded wires out of my harness and i kept running into these things.
Is this a fusible link?
What does it do?
Do i need to keep them or can i cut them out?
Thanks in advance
Old 12-11-2010, 02:06 PM
MeanYellowZ's Avatar
It's not a fusible link, just GM's heat shrinked "splice" connection for multiple wires. You can do whatever you want with it.
Old 12-11-2010, 02:08 PM
Do i just need to ground the wires i cut off then?
gofastwclass's Avatar
Eventually they will lead to a ground lug somewhere or back to the PCM itself. Some lead to sensor grounds or injectors, another is ground for all the coils, etc.
Old 12-11-2010, 05:29 PM
Pocket's Avatar
Thats a common splice. When building harnesses, I cut them out. Some you'll delete when removing unnecessary circuits, most will be spliced back together with a heavier gauge wire grounding to the engine. Its just easier to split them up, do the changes and put them back together in the end
Old 12-11-2010, 05:46 PM
I was really hoping you would chime in.
Thanks for the advice
Quick Reply: Wiring Harness Question
