Vehicle Classifieds - '99 NBM "SS" 11-sec Daily, DONE RIGHT - LOWER PRICE
SSP Racing
12-12-2010, 11:19 PM
1999 NBM Z28 A4, 120k on car. Gray cloth interior, Firebird seats. 18k on Motor, Rear end, Paint. 10k on Trans and susp.
http://farm3.static.flickr.com/2393/4511410143_6ceacf6318.jpg (http://www.flickr.com/photos/kwiker/4511410143/)
IMG_8596 (http://www.flickr.com/photos/kwiker/4511410143/) by kwiker! (http://www.flickr.com/people/kwiker/), on Flickr
I built this car a little over a year ago to be a fun, reliable daily driver. When I say built, about 90% of the car has been completely gone through. I couldn’t begin to add up all of the small nickel and dime things that have been reworked or replaced, so I will cover what I can think of off the top of my head.
Motor: Mild Heads/Cam 347
• 2004 LS6 Block – All machine work (mains aligned, block decked, honed, thoroughly cleaned)
• ARP Main Studs
• Stock Crank, polished with oil mods
• FM main bearings @ .0019”
• Stock LS1 rods with ARP bolts
• Clevite race-coated rod bearings @ .0021”
• Diamond 11500 3.905” Forged Pistons
• Mahle Rings with Big N2O gaps
• Rotating assembly balanced to within .1g
• Durabond cam bearings
• Cammotion Custom Grind – 223/227 .570”/.578” 110+4 (installed -1 for +3 total adv)
• Cloyes Hex-adjust Timing Set
• “LS6” Oil pump
• LS7 Lifters
• Smith Brothers 3-pc pushrods
• Cometic .040” headgaskets
• 4.8/5.3 706 Head Castings
o 59cc chambers
o Minimal, but strategic port work over valves, runners left nearly stock
o Lightweight zo6 2.00”/1.57” Int/Exh valves
o Comp valve job
o Flow like expensive heads
o PAC 1512 Springs with COMP Ti Retainers
• Stock rockers
• NGK TR6 Plugs
• LS6 Intake Manifold
• Ported Stock Throttle Body
• Norris Motorsports Catch Can
• Metco Breather
• TSP 85mm Lid
• LS6 MAF
http://i37.photobucket.com/albums/e82/SSPRacing1/P1030361.jpg
Fuel:
• Racetronix In-tank Walboro Pump Kit
• Hotwire Kit
• FRPP 42lb Injectors
Exahust:
• SSAC Headers customized with SSAC HVMC’s (comparable to something like an LPP header)
• Custom 304SS 3” duals, X-pipe, over the axle, then venturi-reduced to 2.5” at the tailpipe
• V-bands off headers
• One 3” set of Vibrant resonators before axle
• One 2.5” set of Vibrant resonators at tailpipe
• SLP dual/dual tips
• Pictures are before I put the 2.5” cans before the tips.
http://i37.photobucket.com/albums/e82/SSPRacing1/Duals3.jpg
http://i37.photobucket.com/albums/e82/SSPRacing1/Duals2.jpg
Trans:
• Yank PT4000
• Pro-Built Automatics 4l60e “Street-Strip 650hp” Kit (This kit is good for 650+HP with 10" or smaller diameter torque converter. You will start by adding the HD steel sleeve & steel forward piston to the input drum, (2) Street/Strip Borg Warner Hi-Energy 8 clutch 3-4 pack, (3) A "modified" Trans-Go Performance Shift kit, (4) Vacuum modulator. (5) Trans-Go Hi-Rev 3-4 & forward clutch spring kit to the input drum (good up to 7,800 rpm). (6) Sealed Power "Beast" sunshell. (7) Trans-Go steel rings and Hi-rpm priming spring added to the front pump, this keeps the oil volume up at very hi-rpms (up to 7,800 rpm). (8) Borg Warner Hi-Energy 2-4 band. Comes with Duraprene pan gasket, oem filter, front pump gasket & O-ring, O-rings for the tcc solenoid & 4 sealing rings for the input shaft & stator support. Updated Viton O-rings for Corvette servo, 4 tang bronze thrust washer, Torlon checkballs & 3 new aluminum accumulator pistons with seals, two hardened (RC52) accumulator pins for the forward & second accumulators, one oem accumulator pin for the 4th accumulator.) w/ some extras:
o 2-3 Overrun Valve
o Sonnex Super Hold 2nd gear Servo
• All Clutches replaced when built (in addition to the 3-4 pack that comes w/ the kit)
• Trans assembled by Plano Automatic Transmission
• Large B&M 28,000 Cooler
• Hydraulic fittings on trans and cooler
Rear:
• Stock 4-ch 10-bolt
• Torsen Diff
• GM 3.73’s
• ALL bearings and seals replaced
Susp/Wheels/Brakes:
• Eibach Pro-Kit
• Stock DeCarbons off 50k mile car
• BMR Track-Pack Torque Arm
• Custom Bolt-In Crossmember to clear exhaust
• Spohn Rectangular LCA’s
• Spohn Weld-In Relocation Brackets
• Spohn Weld-In SFC’s
• BMR Adj PHR
• Silver ZR1’s:
o 17x9.5” fronts with 6k mile 275/40 Nitto 555’s
o 17x11” rears with 1k mile 315/35 M/T ET Street Radials
• New Pro-Stop Premium Front Rotors w/ EBC Red Stuff Pads (1k miles)
• New House Brand Premium Rear Rotors w/ Premium Ceramic Pads (1k miles)
• Front hubs replaced w/ brakes
http://i37.photobucket.com/albums/e82/SSPRacing1/TqArm2.jpg
http://i37.photobucket.com/albums/e82/SSPRacing1/TqArm1.jpg
http://i37.photobucket.com/albums/e82/SSPRacing1/TqArm4.jpg
http://i37.photobucket.com/albums/e82/SSPRacing1/TqArm3.jpg
Ext:
• eBay Fiberglass “SS” Hood (very light)
• eBay Fibergalss “SS” Spoiler (very light)
• SLP “SS” Grille
• JDM-tite clear turn signals
• PPG Omni base in factory NBM code, but came out much deeper with lots of nice flop to it.
• DuPont Urethane Clear (Lots of it-blocked out real nice NO peel)
• Looks like you can hi-dive into it compared to a stock NBM car.
http://i37.photobucket.com/albums/e82/SSPRacing1/P1030353.jpg
http://i37.photobucket.com/albums/e82/SSPRacing1/P1030359.jpg
http://i37.photobucket.com/albums/e82/SSPRacing1/P1030355.jpg
http://farm3.static.flickr.com/2310/4511410605_5341203dfb.jpg (http://www.flickr.com/photos/kwiker/4511410605/)
IMG_8597 (http://www.flickr.com/photos/kwiker/4511410605/) by kwiker! (http://www.flickr.com/people/kwiker/), on Flickr
http://farm3.static.flickr.com/2015/4512051990_1b9af41a6e.jpg (http://www.flickr.com/photos/kwiker/4512051990/)
IMG_8602 (http://www.flickr.com/photos/kwiker/4512051990/) by kwiker! (http://www.flickr.com/people/kwiker/), on Flickr
Everything else:
• Broke-in motor w/ Torco TBO, then Brad Penn 10-40 (till 3k), since then it has had Torco SR1 5-40 in winter, 10-40 in summer.
• The car currently has a HPT 1-bar MAF-enhanced tune. It idles at 750 rpm and has no drivability issues at all. The rest of the tune is on the conservative side for no-worries pump gas use. It has the correct injector tables.
• Also worth noting: The A/C compressor, Accumulator, Alternator, Water Pump, and Radiator were all replaced with the motor (all W/ GM parts). A/C and all that works…CD changer quit working. Front door speakers are iffy.
• Car is in all ways daily-drivable. The only thing that takes away from streetability in my opinion is the ring gap + breather - cats = makes it stink. The converter is easy to get used to w/ the 3.73’s.
• I put 18k miles on it 80% highway driving from McKinney to Denton every day.
• Never wasted my time w/ dyno #'s as they would be scoffed at, questioned, and criticized in comparison to everyone’s donkey-dick cam 6-speed car.
• FWIW, right after I built the car it still had 100% stock suspension minus the pro kit and I was running a SS3600. The first trans build was iffy at best – pump springs wouldn’t hold pressure right on 2-3 shifts when starting from a dig. I made one pass at Crandall like this one night before the rain started and went 11.80 @ 113 1.65 60’. The car had a long 2-3 hangup so bad I had to lift all the way for it to shift. 3rd slipped all the way through traps-Trans was done after one pass, had to go into it the next day, 3-4’s were gone. This was on 17” Nitto DR’s. The car is night/day quicker with current trans, converter, suspension, and tires. Should be an easy 11.30, 117+ car in daily trim. The car is a bigger cam and some juice away from being decently quick. The motor should handle a properly-tuned 150-200 shot all day.
Recap:
• The car is essentially mechanically new – Everything done to car has 18k or less.
• Paint is new too
• Interior is 6 out of 10 (I will try to take some pics this week).
• It is built to take daily abuse and quick enough to get you into trouble – with potential to be much quicker if you want to race it.
I haven’t driven the car in 2 months. I have no time to enjoy it anymore with my new job. However I am just as happy keeping the car as I would be to sell it. 6 one, half dozen the other to me. I am in no hurry. If I keep it, it’s getting gutted, getting a bigger cam, and a fat 150 shot then sitting till I can play with it.
*REDUCED* $9,750 OBO – More incentivized to sell. Offers do not hurt my feelings.
I will have limited time to log in to Tech over the next few weeks, so please text or email with serious inquiries.
John: 214-six seven four-0141 or j.cangelosi (at) yahoo dot com
SSP Racing
12-15-2010, 12:10 PM
to the top...
SSP Racing
12-19-2010, 04:55 PM
TTT... Also would trade for a clean 60-70's GM Muscle Car (Nova, Camaro, Chevelle, Impala, Cutty, GTO)
SSP Racing
12-23-2010, 07:48 PM
Ttt...
Dixon79lt
12-23-2010, 08:31 PM
Beautiful car. you have a pm.
SSP Racing
12-28-2010, 05:49 PM
Dirty interior photos (been driving car again). I'll clean it up this wknd and take more.
http://i37.photobucket.com/albums/e82/SSPRacing1/CIMG0012.jpg
http://i37.photobucket.com/albums/e82/SSPRacing1/CIMG0011.jpg
http://i37.photobucket.com/albums/e82/SSPRacing1/CIMG0010.jpg
94slobra
12-28-2010, 06:13 PM
Trade for 1971 Chevelle in the for sale section? You would have to add some cash though. Let me know
SSP Racing
12-30-2010, 05:14 PM
bump...
SSP Racing
01-02-2011, 05:13 AM
$9,750 :nod:
SSP Racing
01-08-2011, 05:21 PM
Ttt...
Brandon331
01-13-2011, 12:54 AM
trade http://atlanta.craigslist.org/atl/cto/2156062517.html trade plus 5300?
sfd963
01-13-2011, 11:39 AM
would you be interested in a 07 nice cbr 1000rr only 3700 miles. modded
philaeagle51
01-13-2011, 11:46 AM
trade : 2002 camaro z28 a4 23000 miles, clean all around. SLP lid CAI bellow, SLP loudmouth, diablo predator sport tuner. made 360rwhp and 379tq on dyno. factory freak engine
SSP Racing
01-17-2011, 06:15 AM
Sounds nice, but no thanks. I am really just after cash at this point unless something different really jumps out at me.
SSP Racing
01-20-2011, 05:24 PM
To the top...several bites, several offers...some deals may be pending. Keep them coming ;)
94 s dime
01-22-2011, 11:25 AM
i am thinking about listing mine up soon, good looking car here forsure especially for the price..BUMP
SSP Racing
01-26-2011, 11:16 PM
Possibly one of the last bumps...
SSP Racing
02-03-2011, 12:10 PM
Nothing in stone yet.
blackz28x07
02-03-2011, 12:24 PM
Interested in an 03 trailblazer 4X4?
key4
02-03-2011, 03:48 PM
still waiting on the video, guy is coming to pick my car up saturday
Brandon331
02-08-2011, 02:23 AM
is this car still for sale?
Teakwo23
02-18-2011, 12:07 AM
love it
Silver408
02-20-2011, 08:39 PM
Is this beast still for sale?
