Need to adjust my hood
One of my headlights gets caught to my hood and doesn't pop open all the way. How do i adjust it this? when i pop the hood open the headlights pops up fine. thanks for any suggestions
i replaced the low beam yesterday because it went out. after that i shut the hood and turned them on to make sure they worked and thats when it didn't pop up all the way. it rubs against the hood. I live in garland.
I'd start by loosening the bolts that hold the housing to the radiator core support and then pull the headlight towards the front of the car and hold it while you tighten the bolts back down.
I changed both low beams on both sides of the car. The left side works fine but the right side is the one getting stuck. It was harder to removed the right side. I dont know either. ill take some pictures of it later on so people can see what exactly is going on.
