LS1 Harness Connection Map
Old 12-13-2010, 08:29 PM
warpdriv's Avatar
Default LS1 Harness Connection Map
Hi Everyone,
I'm turning into the home stretch of my conversion, http://forum.ih8mud.com/80-series-te...-ls1-swap.html
Since I'm new to LS1s, I need to learn what all these sensors are all over the engine are. Is there a link that lists them all out and more importantly, where they are on the engine? Or should I buy a FSM for my engine? I read the FAQ and did not find the answer.
Thank you for your help.
Old 12-13-2010, 09:09 PM
Earl Filter's Avatar
I know what you're looking for, but don't know where a comprehensive list is. Something like this, but for an LS1:
http://shbox.com/1/component_location_views.html
And did you figure out that 2nd return on the PS pump? Hydroboost for the truck brakes. You can cap it, or tap it and put a bolt in it.
If you don't luck out, you might pay for alldatadiy.com. That's what I'm going to do when I get that far.
Old 12-13-2010, 11:37 PM
gMAG's Avatar
This might help...
http://www.chevythunder.com/ls1_page_1.htm
Old 12-14-2010, 08:02 AM
Pocket's Avatar
http://www.thirdgen.org/techboard/lt...formation.html
http://www.thirdgen.org/techboard/lt...erchanges.html
Old 12-14-2010, 07:55 PM
warpdriv's Avatar
A gold mine of information! Thank you!!
Old 12-16-2010, 06:28 PM
warpdriv's Avatar
It was for a PS fluid reservoir.
What is this? It had line connected to it that ran into the fuel line. I though it was the return until I looked a friends engine. He just had his capped off.
Old 12-16-2010, 07:03 PM
Pocket's Avatar
EVAP
Delete it unless you're in a smogger county
Old 12-16-2010, 09:33 PM
warpdriv's Avatar
Originally Posted by Pocket
EVAP
Thank you.
Quick Reply: LS1 Harness Connection Map
