05blackgto
12-13-2010, 09:02 PM
can anyone give me a guess of how much rwhp i should make with a 408, stock gears and m6??
this is what the 408 has...
Wiseco forged pistons with steel top rings 11.5 compression
Callies h beam rods
Callies 7340 forged crank 4.000 stroke
Clevite rod and main bearings h series race application 178.90
Durrabond cam bearings
Ls6 ported high volume oil pump
Rollmaster dual roller timing chain with torrington bearings
Ls7 lifter set
ARP main studs
ARP head studs early version 6.0 block
ms4 cam
Front timing cover gasket, damper seal,rear cover gasket,rear main seal, water pump gaskets. oil pan gasket
prc 215 heads
pacesetter headers 1 3/4"
stock ls2 intake
volant cia
also i might run a custom cam.....thank you everyone!!!
Shipping 78.98
Callies h beam rods
Ls7 lifter set
ARP main studs
ms4 cam
prc 215 heads
stock ls2 intake
volant cia
Shipping 78.98
