Is the radio harness all I need?
I just bought an alpine ida-x200 off my buddy, but I don't have the harness that came with the hu. If I get a replacement from ebay as well as everything here: https://ls1tech.com/forums/2743520-post5.html will that be all I need? And what about the rca plugs in the back of the hu, will any of the harnesses have the plugs on them?
Metra Pn's: 40-GM10 (ant adapter), 70-1858 (alpine harness to OEM harness adapter), 99-3300 (dash kit)
The RCA plugs running from the back of the HU are most likely subwoofer outputs, front/rear outputs and/or aux inputs. Try and download an instruction/installation manual for that specific HU. It will also help when you wire up the Alpine HU harness to the adapter harness. Hope this helps
Chris
If you want it right now, even most Walmarts carry at least the harness, and if that fails, you can get them from BestBuy (but it's gonna cost you a lot more).
It will come with tail ends for pos, grnd, acc, illum, front +/- L/R, rear +/- L/R, etc...You will have to splice or solder into your aftermarket HU harness
sjsingle1 pm'd
Ok one more thing, everything is plugged in and working with my alpine hu but what did this plug do? It came out of the old hu but doesn't plug into anything now.
