LT1-LT4 Modifications - Gains from CAI to Lid?
Lawhead
12-14-2010, 12:32 AM
All the things i find online are people going from stock to the LS1 Lid
But what would the gains be with the CAI to the Lid?
trilkb
12-14-2010, 12:46 AM
the real question is, how much do you like your car? Do you have ram air hood or a stock hood? reason i ask is 1 youll be doing alot of cutting to the car, and 2, better get ready to start hacking up the underside of your hood as well. i assume its not ram air since you have a CAI.
there are gains to be had, but mostly they are in the 1-2tenth area. on a camaro its no big deal, on a firebird its a little more tricky. Some people dont want to cut up their car just for that. but it has been proven then intake temps do lower by quite a bit over a CAI. The engine also sucks in more air.
Im glad i did mine, personally i think it looks badass to see a ls1 lid under a lt1 hood lol. but if your not into cutting your car up it may not be the mod for you. you can make the Radiator support look clean, but under the hood your still gonna have a nice size chunk that needs to come out, basically the outline of the LS1 lid.
Lawhead
12-14-2010, 12:53 AM
Well planing on doing the LS1 front clip conversion.
But with that i was also thinking will the Ram air line up where it needs too I think i seen something about the LT1 sitting higher then the LS1 Vise-versa
hitmanws6
12-14-2010, 12:57 AM
The gains are around 2 tenths and 2 mph
trilkb
12-14-2010, 12:58 AM
honestly it would be easier to buy a lt1 ram air hood and then either do the lt1 ram air setup or the ls1 lid. Then just like the camaro you wouldnt have to worry about the hood and what not. its really the stock lt1 trans am/firebird hood that makes it a pain.
Lawhead
12-14-2010, 12:59 AM
well damn that almost makes my car a 12 sec car :o
but with the Ram air front end conversion should i see even more gains?
hitmanws6
12-14-2010, 01:14 AM
The WS6 lower airbox is bigger than the normal airbox, but ive never seen the gains. I do know that the LT1 WS6 setup and the normal lid setup will net the same gain though
Lawhead
12-14-2010, 01:29 AM
So going with the big air box with my LS1 lid conversion ya think?
Lawhead
12-15-2010, 04:51 PM
This is what made me think of doing the swap and now someone on here told me it just about a direct bolt on so
http://www.zainobros.com/files/photos/silvertalg.jpg
I mean come on how can you not like that lol
zlover129
12-15-2010, 04:52 PM
....really :eyes:
Lawhead
12-16-2010, 06:16 PM
....really :eyes:
haha seems like a mod worth while to me .2 is the difference between your car running 13.2 and 12.99
RamAir95TA
12-16-2010, 06:30 PM
An engine will only breathe in as much air as it needs. The gains from this modification are only because other setups are more restrictive. You cannot force-feed a motor more air than what it would normally use (unless you're using FI).
Lawhead
12-16-2010, 06:32 PM
R3D who did the CC503 swap over on Lslt1.com said when his car was stock it helped big time from the K&N to the Lid. so we shall see
RamAir95TA
12-16-2010, 06:41 PM
Right...so?
trilkb
12-16-2010, 06:50 PM
Faster times > more power/better grip/less weight > more air or fuel/more traction..... i dont beleive you touch the fuel system or the tires when doing this mod. The only thing changed is the air intake, thus changing the amount of air comming into the engine, also changine the amount of fuel comming into the engine.
That make more sense or do you want to roll your eyes some more
LT1559
12-16-2010, 06:56 PM
There's a thread on here that someone actually posted, i'll try to find it. but if i remember correctly that someone did a 1/4 mile run with a cai tuned then a 1/4 run with a lid tuned. the results were quite impressive.
LT1559
12-16-2010, 06:57 PM
http://www.ls1tech.com/forums/lt1-lt4-modifications/1348674-ls1-air-lid-dyno-numbers-before-after-comparison.html
hitmanws6
12-16-2010, 07:03 PM
I believe most of the gains are from IATs dropping and not so much airflow. I went from a CAI to the WS6 setup in a matter of about 10 minutes and felt a noticeable difference. The CAI flows enough CFM but the IATs are higher than a lid because of where the air is coming from.
trilkb
12-16-2010, 08:38 PM
i did some runs. My et dropped and i think i gained a mph. there was some controversey over the times due to the DA but all in all my car went faster, this was untuned and with the trans cooler blocking alot of air flow since i didnt cut everything i shouldve.
zlover129
12-16-2010, 10:33 PM
The volume of air entering the engine has nothing to do with the intake...unless it's super restrictive, the gains being seen are not from a difference in volume but from the less restrictive piping and probably due to lower iat's. If you took the intake off completely and ran just a throttle body you think it will suck in more air? The answer is no
I personally think it's quite a bit of work for the gains, my car made quite good power without one but props to those who go through the effort and do it clean and make it look like it belongs.
gregrob
12-16-2010, 10:46 PM
It will feel like a phucking 100 shot, swear to GOD
Lawhead
12-16-2010, 10:50 PM
it will feel like a phucking 100 shot, swear to god
ohhhhhhhhhh really now
gregrob
12-16-2010, 10:53 PM
Honest
Lawhead
12-16-2010, 11:07 PM
do you have it done to your car Greg?
gregrob
12-16-2010, 11:11 PM
Yeah.
Lawhead
12-16-2010, 11:14 PM
Yeah.
man of many words.
would you be able to give an in depth explanation on how it helped :chug:
gregrob
12-16-2010, 11:18 PM
Not really. I did it along with my cam swap, so I dont have a direct comparison.
I think it helps though. It helped z28camaro30anns car pull harder in the upper rpms, where the factory junk was probably the most restrictive.
Its not like a huge must have, the Moroso style CAIs have been working for people for years, but I do feel there is some benefit to be had.
Besides I just personally hate all the twists and turns of the normal LT1 style CAI's. I think a free flowing inlet is just as important as a free-flowing exhaust.
If you really want to see if its going to help, see if your car pulls a vacum at wot with the stuff thats on there right now, if so it will help. If not you probably wont notice much.
bolek
12-17-2010, 10:47 PM
I switched from Moroso cai to LS1 lid a few weeks ago.
It feels pretty much like when I replaced stock intake with
Moroso cai. $50 lid + $14 filter, for what appears to be about
10 RWHP, seems like a good deal to me.
I like this mod.
dubga
12-19-2010, 12:44 AM
K&N CAI - Best run 13.82 @ 100.938
LS1 Lid - Best run 13.69 @ 102.005
Both times are DA corrected to sea level.
