LG G5X4 and PRC stage 2.5 5.3 heads.. PTV issues?
I currently have the G5X4 cam in my car and just got a deal on some TSP PRC stage 2.5 5.3 heads i need to know if im going to have PTV issues, im thinking i may have to flycut, anyone else running this similar setup please chime in. Thanks
LS1Tech Premium Sponsor
Yes you will need to flycut. The X4 doesn't have very good p/v so the larger valves will definitely require cutting. The only heads we can confirm will clear is the PRC Stage 1 LS6 heads & the PRC 215 heads.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
