Who has used GTO Spares on a Camaro?
Old 12-14-2010, 06:59 PM
philsblwnz28's Avatar
Default Who has used GTO Spares on a Camaro?
I was wondering if you had to have a spacer when using GTO Spares for skinnies on a 98-02 camaro? Thanks
Old 12-14-2010, 09:00 PM
95TAJade's Avatar
If you open up the hub diameter a little bit you don't need to run spacers. But I would if you ever plan on taking them off and running something different. I've had to replace a few wheel studs cause of the stress caused by tightening the lug nuts while I was running GTO rims on my car. Not b/c of over-tightening; 4 outta 5 studs have plenty of clearance but only 1 is just enough outta alignment.
Quick Reply: Who has used GTO Spares on a Camaro?
