04 gto guys come on in
Im getting ready to install my motor in my swap. There are a bunch of small metal tubes coming off and around the throttle body. Can someone post up some pics of where these are connected to?
thanks in advance
thanks in advance
The top tube on the passenger side connects to the vent tube on the valve cover. The two lower tubes are for coolant hoses. One runs to a barb on the top of the radiator. The other goes to a T fitting on the crossover tube that connects to the two heads in front. I have done a coolant bypass, so mine are no longer connected. Supposed to add a little power without the cooling lines attached to the TB. Just connect the rad to the crossover line directly.
