Your little tips and tricks?
Old 12-15-2010, 09:21 AM
camar0corey's Avatar
Default Your little tips and tricks?
I'll start off with a few I've learned.
I use a jack to hold headers close to the height I need them at, header installs go a lot quicker now.
I use a foot long piece of rigid pipe for a breaker bar. If I don't have that around I use a larger closed end wrench on the smaller wrench or ratchet.
I posted it in another thread, but pipe tape on header bolts for bolt retention.
I always use the 3/8" bolts so that it is easy to get tools on and off the header bolts, and I use a longer craftsman wrench that is closed end both sides, one 3/8 and the other 7/16 so you have both common header bolt sizes and leverage.
If you just start to round off a bolt head you can try a few layers of tape and then tap the socket down. Just picked this useful technique up two weeks ago. I still much prefer the proper tool for this though, but if you are away from home or something, good thing to know.
So what are some other things you all do that might make life easier?
Old 12-15-2010, 11:41 AM
LSWHO's Avatar
first one that came to mind:
When getting the top tranny bellhousing bolts back in. Use a LONG extension from the tailshaft area. Fold a small piece of paper in with the bolt into the socket to keep it there, then move it into the hole and thread in. The paper keeps the bolt in the socket enough to keep it from falling off and comes off easy when pulled. If you use a swivel socket to get a better angle, you can tape it so that the bolt is held out still in case your swivel is so loose that it flops down all flaccid like.
Old 12-15-2010, 11:49 AM
boostedlt1's Avatar
wish i had known/thought of that. good one!
Old 12-15-2010, 12:00 PM
RamAir95TA's Avatar
Common sense and a diverse selection of tools. That's about the only tip or trick you need.
Old 12-15-2010, 12:10 PM
Matts94Z28's Avatar
Fix it till it's broken.
Old 12-15-2010, 12:24 PM
LSWHO's Avatar
Thanks, that was my brainchild.
Old 12-15-2010, 12:30 PM
moehorsepower's Avatar
when a bolt starts to get rounded off, instead of putting a piece of paper I have used a piece of sand paper, the grit will help grab the bolt..
Old 12-15-2010, 12:38 PM
quik95lt1's Avatar
yep exactly how i do mine...i actually fold it in with a little piece of duct tape the glue on the tape works mint......then yea i make about 36inches of extension and tighten it from out back near the tailshaft lol........i can do a trans swap in like two hours in and out now......works like a champ.....i tape my swivles a little to to keep them in the right orentation....
Old 12-15-2010, 03:25 PM
draggin97s10's Avatar
my tip was gonna be to tape the swivels, to do tranny installs by myself i built a trans adaptor for my floor jack out of an old jack plate. took it some 1/4 plate steel and angle iron. now i dont need another hand do tranny swaps. otherwise let air tools be your friend, my friends.
Old 12-15-2010, 03:49 PM
the_merv's Avatar
I tape all my swivels.
Ratchet Straps work good for installing Transmissions.
Bought a G-body.
Old 12-15-2010, 03:59 PM
Bought a G-body.
I used to use ratchet straps untill i looked at my welder one day. congrats on the g body
Old 12-15-2010, 04:21 PM
the_merv's Avatar
Welder..what happened with that?
I got this Monte Carlo SS after my 98 wrecked.
I have one word that describes this car:
Room.
Old 12-15-2010, 04:32 PM
Room.
i used it to make the trans plate floor jack adaptor thing i described in earlier post
Old 12-15-2010, 04:33 PM
the_merv's Avatar
Ahhhhhh I see..read that wrong..lol..
Old 12-15-2010, 06:12 PM
AChotrod's Avatar
WTF???? You wrecked your car?
Old 12-15-2010, 06:17 PM
hashtagBMW
Speed Density's Avatar
haha, classic.
Tools and common sense is probably it for me. I dont know any "tricks" really. I do have a POS though.
Old 12-15-2010, 08:52 PM
the_merv's Avatar
Ya..where the fck u been?
Old 12-15-2010, 09:01 PM
1badzee's Avatar
Pics of said G-body or BAN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
actually, pm me. no reason to clutter this place up any more
Old 12-15-2010, 09:07 PM
the_merv's Avatar
Here..I'm sure other people are interested aswell..
I have a ton of mods going in it.
Old 12-15-2010, 09:12 PM
1badzee's Avatar
looks clean buddy! was always a fan of g-bodies.. turbo regals specifically
Quick Reply: Your little tips and tricks?
