Can I use Patriot Stage 3 on My Engine Setup
I have N/A LS1 engine with full bolt (full exhaust, fast 90/90, pully, Ram Air) and mid range cam.
I am planning to get the patriot stage 3 with Part No. 2015
Combustion Chamber: 64cc
Intake Runner: 227cc
Exhaust Runner: 70cc
Intake Valve: 2.08"
Exhaust Valve: 1.60"
Is it ok to run them on my setup or I need something else ? because it is written in their web site that they are a great choice for 4.00” and larger bore motors due to their valve size
But I heared some people install them with same setup as mine without any problem
I need a confirm before I get them
Intake Valve: 2.08"
LS1Tech Premium Sponsor
Agreed, not so much due to runner but valve size. I'd check out the PRC Stage 2 LS6 heads if you're looking for something better suited for a stock cubed LS1! They are on special for Christmas right now ($150 off)!!
http://www.texas-speed.com/shop/item...d=134&catid=40
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
