Motovative Performance introductory sale! Intake Elbows, Valley Covers, Motor Mounts
Old 12-15-2010, 06:21 PM
Motovative's Avatar
Default Motovative Performance introductory sale! Intake Elbows, Valley Covers, Motor Mounts
We have decided to step up and support the community that supports us. We are proud to officially become a sponsor and offer our innovative products at an affordable cost. Some of you may recognize me as "xssive" here on the forums, and I am now posting officially as the Motovative Performance rep here on ls1tech.com.
We are going to start of with a sale on our most popular items, and pricing will be going up on these!
Motovative Performance Sheetmetal Intake Elbows
-1/2" 6061 Billet Aluminum Flanges
-Both 4150 and 4500 Dominator base flanges available
-Precision machined to exacting tolerances
-Ford and GM TB Flanges available
-Fully TIG welded
-3/4" base flanges available for 15$ extra
Introductory pricing on these is 200$
LS1 F-Body solid motor mounts that are unrivaled by any others on the market. These pieces replace the stock rubber or poly clamshell mounts and can be used with any aftermarket or stock k-member that uses a stock style mount. Unlike competitors products, THESE WILL NOT RAISE YOUR MOTOR, and are a simple bolt in installation.
These are manufactured from laser cut mild steel and are built to match factory motor mount dimensions to within .005" tolerances.
We are offering these at an introductory price of 100$.
UPDATE ! Installed pics :
https://ls1tech.com/forums/generatio...-design-2.html
Motovative Performance LSX Intake Flanges
-Oversized Cathedral ports to accommodate the largest of aftermarket port designs
-Countersunk holes to accept socket head cap screws
-Mitered for valley cover clearance
-Priced and sold individually
Designed with the fabricator in mind, these flanges are the perfect foundation to an aluminum sheetmetal intake manifold. These are for cathedral port LSX based heads. Order 2 Qty for a matching pair.
Introductory pricing on these is 180$ for a pair.
Motovative Performance LSX Valley Cover
-3/8" 6061 Billet Aluminum
-3/4" NPT threaded port for crankcase evacuation / breather sysem
-Satin brushed finish
This valley cover is machined to accommodate a 3/4" NPT fitting when plumbing a crankcase evac / breather system. This is a must have item for high end motors with vacuum pumps. The hole can also be plugged for NA applications. The 3/8" thickness provides structural integrity that highly stressed blocks need.
Introductory pricing on these is 90$.
Motovative Performance LSX Water Pump Block Adapters
-3/4" 6061 Billet Aluminum
-Tapped for 3/4" NPT fittings
-Machined to clear stock and aftermarket timing covers
-Priced and sold as a pair
LSX Water Pump Block Adapters are the best solution for cooling system space constraints in a high performance LSX build. These block adapters are threaded to fit ANY 3/4" fittings, giving the builder the option to design their cooling system as needed. These are perfect for using a remotely mounted water pump in both N/A and forced induction builds.
Introductory pricing of 85$.
All orders can be placed by PM'ing me, as we are in the process of getting our website setup for ordering. You can look at my personal user name "xssive" for a trader feedback reference.
Old 12-16-2010, 06:14 PM
Motovative's Avatar
TTT, thanks for the order. Look for the motor mounts in an upcoming GMHTP project car build!
Old 12-19-2010, 04:05 PM
Motovative's Avatar
Ttt...
Old 12-20-2010, 06:22 PM
subhumanzz's Avatar
i dont see the mounts on your page. where do you order?
Old 12-20-2010, 07:07 PM
Motovative's Avatar
You can order by Pm'ing me
We are still working on the webpage.
Thanks!
Old 12-21-2010, 11:08 AM
WS.SIX's Avatar
Really wish you guys had these mounts earlier... oh well
Old 12-24-2010, 04:41 PM
Motovative's Avatar
Thanks for all the business and support. All orders have been shipped.
Happy Holidays to all!
We are going to continue this sale through the new year due to the success we have seen thus far!
Blake
Old 12-26-2010, 07:29 PM
Motovative's Avatar
Still have a few sets of motor mounts on the shelf at this price guys!
Old 12-29-2010, 07:53 PM
Motovative's Avatar
Ttt...
Old 12-29-2010, 08:22 PM
ZexGX's Avatar
Hi, I am guessing for one to use your LSX valley cover, you need to eliminate the factory LS1 knock sensors??
Old 12-29-2010, 08:26 PM
Motovative's Avatar
That is correct, or relocate them
Old 12-31-2010, 06:59 AM
Motovative's Avatar
Ttt...
Old 01-02-2011, 02:32 PM
Motovative's Avatar
Ttt...
Old 01-03-2011, 01:52 PM
Motovative's Avatar
We have 20 sets of mounts back on the shelves. Order ship immediately!
Old 01-06-2011, 12:57 PM
Motovative's Avatar
Ttt...
Old 01-07-2011, 06:25 PM
Motovative's Avatar
Ttt...
Old 01-09-2011, 04:52 PM
Motovative's Avatar
Ttt...
Old 01-11-2011, 06:34 PM
Motovative's Avatar
Ttt...
Old 01-20-2011, 08:02 PM
Motovative's Avatar
Ttt...
Old 01-22-2011, 06:41 AM
Motovative's Avatar
Ttt...
Quick Reply: Motovative Performance introductory sale! Intake Elbows, Valley Covers, Motor Mounts
