Generation III External Engine - Drive without front o's hooked up?
98ws6blk
12-16-2010, 08:52 AM
So I'm putting some headers on my car.
My exhaust guy says I need to wait until I have everything hooked before he places the o2 bungs to make sure it's in the correct location.
Is there a way I can drive my car to the exhaust place with the front o2s unhooked or outside the exhaust pipe?
trans_am7935
12-16-2010, 09:27 AM
......:dark: the O2 sensors help the car run its air/fuel ratio, so that answer is no. just put the o2 bungs right after the collector on the longtubes.
senicalj4579
12-16-2010, 09:29 AM
I wouldnt drive it. Your headers dont have bungs welded in already?
Sales4@Texas-Speed
12-16-2010, 09:58 AM
It would be very difficult to drive the car without the front 02 sensors if the computer still reads off them. The computer will basically want to dump a bunch of fuel in the motor to keep it safe since there are no sensors to tell it whats going on. Usually long tube headers come with 02 bungs already welded in for the fronts.
98ws6blk
12-16-2010, 10:09 AM
I'm only driving about 5 miles...?
They are a race style header, so the bung has to be welded in.
Greekey
12-16-2010, 11:47 AM
Don't do it. Have you car towed there.
O2Form
12-16-2010, 02:28 PM
You can drive it...it just won't go into closed loop.
98ws6blk
12-16-2010, 02:47 PM
Yeah, my exhaust guy said people do it all the time. I doubt it will hurt anything for that short of distance.
omarrakeen
12-16-2010, 02:49 PM
WTF why would it be hard to drive it with no o2's? or even tow the car, seriously? dude there are harms yes. but can you drive your car with no O2s? yes you can and also 5 miles are nothing your check engine light probably wont even lit in that distance...dont worry about it
HAZ-Matt
12-16-2010, 05:27 PM
Every cold start you are essentially driving without O2's until they warm up enough to make the car go into closed loop.
It seems odd to me that your headers don't already have O2 bungs in them. And even odder still that someone needs to see them on the car before they add the bung since there is basically only a few spots on the collector where you should put them anyway.
01ssreda4
12-16-2010, 11:48 PM
Seriously, drama queens, calm down. The shit will be fine. There are several occasions in normal driving where the computer doesn't use the 02s to run the motor.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
