Any Idea how long to have the #3 spark plug wire to go over the valve cover
Burnt the wire have some long spark plug wire i was going to use till i got a full set. any idea how long it will have to be cars hot right now just got home from work just ideas if its not long enough i guess ill have to go back under it but tuck it in the block girdle and zip tie it in there.
You burned the one on cylinder number 3? weird mot time people have problem with sparkplug wires its on the passager side. anyway it not difficult, like ramair said use tyraps. U can use a heat sleeve too.
I did not have problem with cylinder number 3 but this is what I did with the one I had problems. I had the msd 8.5 lt1 sparkplug wires kit, i used the longest wire and with the help of tyraps routed that one over the VC, not so nice, but its not a show car and works good.
Can i reuse the side that goes to the opti? if i take it apart and be careful with it. this is just a quick fix so i can get to and from work until pay day when im getting the American Thunder of the valve cover wires and just get rid of this problem all together
