MIL - Check engine light issue
I can't seem to get the check engine light to work. I've got an led with the positive side wired to ignition and the negative side to the brown/white wire. The pcm is throwing a MIL circuit code. It's a 2000 f-body engine / harness.
Has anyone had this issue before? Maybe I'm missing something.
found the problem - previous owner of the harness cut the wire at the pcm - fixed and it works now. Funny, the harness was advertised as with "no cuts" and it had this and the egr pigtail cut off.
thanks for the help guys
