Throwning p0343 code
Old 12-16-2010, 12:09 PM
Turd Gen Guy
1nasty86's Avatar
Default Throwning p0343 code
I went to get tuned last nite only to have proplems. It cranks then dies when the 100mm maf is connected. I unug the maf and it runs fine. But still has the code. I have the ls1 computer with a ls2 engine so I swapped the outside wires. I also pulled the sensor out and there are no signs of contact between the sensor and the gear. Can anybody help
Old 12-16-2010, 12:47 PM
Frost's Avatar
343 is cam sensor input high voltage; has nothing to do with the MAF. High voltage means that either the sensor is bad, or you are feeding straight reference back to the PCM.
Old 12-16-2010, 01:28 PM
Turd Gen Guy
1nasty86's Avatar
I ordered a new sensor. It should be here tomorrow. How would I check if it was feeding back?
Old 12-16-2010, 04:16 PM
Frost's Avatar
As I mentioned in PM, have seen the code when the cam gear bolts backed out as well.
Quick Reply: Throwning p0343 code
