Cost to sleeve a LQx block
I know that it is more popular to sleeve an aluminum block, but what about the Irons? How much does it cost to resleeve an iron with a set of the Darton MIDs, Dry, or Wet sleeves?
DM
DM
Moderator
There are MID sleeves out there for the late model iron Hemi engines and it's pretty standard practice to sleeve old SBC iron blocks for repair, so I don't see why you couldn't sleeve an iron 6.0L block.
I would imagine MID sleeves would cost are pretty much the same as doing an aluminum block since it's basically the same process, but I think if you're just sleeving it down for a smaller bore, you can do that for pretty cheap since the sleeves are cheap (RE: Badger sleeves) and I don't think the process is as complicated as an aluminum block.
Noone is making sleeves intended for letting you turn a 4"-bore LQx into a 4.125"-bore LQx. And they're not going to. Because it's cheaper to just buy a new L92 block. That'll go to 4.125" bore with the sleeves it has. Plus it's aluminum. If you insist on 4.125" bores in an iron block, you'll have to buy the GMPP LSX block.
If you want 4.250" bores, the iron GMPP LSX block will do that too.
World's Warhawk block is another option
LS1TECH Sponsor
Sleeving the iron 6 liter blocks
I MID sleeved one for Erik At HKE a few years back. The LS1 LS6 MID sleeves work in these blocks allowing bores to 4.200".
It is however expensive to do because iron machines much more slowly than aluminum. It would run right around three grand to MID sleeve the iron GM block.
I do machine the 6.1 Hemi blocks for MID sleeves, with three on the way in right now in fact.
The LSX iron block is a cheaper alternative but of course the cylinder walls are on the short side for long strokes. It may be possible to dry sleeve the LSx blocks using the 5.8" long Darton Seal Tight dry liners. I will check that out next time I get an LSx block in.
Steve
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Steve Demirjian
Oceanside, Ca.
760-630-0450
Well what about a wet or dry sleeve for the LQx block; I'm guessing that it would be cheaper than the MID option?
You also bring up one reason I have been looking into this... My crank is a 4.125 so to have a deeper cylinder is one reason I've been looking into this. And to have a 4.2 bore with a 4.124 would make for a dirty little ***** of a motor
DM
DM
LS1TECH Sponsor
Sleeves
The MID is a wet liner, which is the only option for the iron 6 liter blocks. There is no way to dry sleeve the block using the dry liner I had Darton make for the aluminum blocks. There is not enough iron in the block to support dry liners. MID sleeves are self supporting with more than adequate thickness to hold a lot of power.
Let me attach a photo of the one I did for Erik, prior to decking and finish boring, so you can see what it looks like.
Steve
Steve
DM
DM
__________________
Steve Demirjian
Oceanside, Ca.
760-630-0450
Steve Demirjian
Oceanside, Ca.
760-630-0450
Steve
Steve
So it's about $3k to do this to a LQx... I still have my LS1 in the Bird, what would it run to sleeve that with MID or Dry with a long sleeve for a 4.2 bore?
DM
