need help with master cylinder line
Old 12-18-2010, 12:32 AM
2formulas's Avatar
Default need help with master cylinder line
I just swapped my master because the old one was spewing brake fluid all over my floorboard and clutch pedal. Anyway, I can't get this steel braided line back into the slave. I followed the steps in install u, opening the bleeder to relieve system pressure, but still no luck. How hard do you push on this thing? Do I need to do anything with the little white plastic ring when I'm pushing the line back into the trans? HELP!
Old 12-18-2010, 12:14 PM
2formulas's Avatar
anybody?
Old 12-18-2010, 05:06 PM
RedRallyeZ's Avatar
You're more than likely doing it right, it's just tough sometimes. I used two flat head screwdrivers to push that little white ring in. You're feel it click, but it just takes patience
Old 12-18-2010, 05:40 PM
2formulas's Avatar
Thanks! It's back on, now my clutch pedal is squeaking.
Quick Reply: need help with master cylinder line
