will tires effect ABS?
I have 18's all around and Im getting 285/40/18 for the rear and trying to keep what I got up front(285/30/18) for now. The question is will this effect my ABS since there is such a difference in height. If so what would be a good size tire for the front?
The front are rears have to be less than an inch apart from each other in overall diameter in order to keep the ABS light off.
I use this calculator to figure out overall height when I'm trying to figure sizes out:
http://www.discounttiredirect.com/di...foTireMath.jsp
The first time I drove my truck after I switched from 30" tires to 33" tires I almost rear-ended someone and actually had to pull off the road to avoid hitting them. I had the brake pedal pushed down as far as I could but I couldnt stop in time, I ended up just taking out the ABS fuse and disabling it
^ you can recalibrate your truck and it will fix that as long as you have 33's all the way around.
Fronts and rear have to be within an inch apart.
The 40 series doesnt matter. What matters is the overall diameter of the tires(need to be within an inch apart). When they are different sizes you cannot individually calibrate front a rear ABS sensors.
