helicoil spark plug?
I recently installed my heads and notice 2 plug arent treading right! so I tighted it as much as possible but its not right! can anyone local fixed the plug holes without taking off the head? they are the two center ones on driver side!
thanks!
santana
thanks!
santana
They make taps for that, or you could possibly get some old or new spark plugs since theya re cheap and cut slits into the threads to make it like a tap. Make sure you put some grease on it so it can catch most of the shavings.
Taking it apart is easy. If you can work a socket/wrench you can do it Santana.
This isn't one of those thread that get put up every week in every section even though there are dedicated sections for it, like what cam is good or will 1 7/8 headers work.
ive seen that get it and put a slice on it so it acts like a tap and someitmes works and fixes the threads.. good suggestion, or go to oreilly they even sell the tap for spark plug holes like 10 bucks
Yes, do this. This is the first thing to try. I would drop the header so you have plenty of room and try the thread chaser. If it doesn't work then heli-coil them, it's easy to do and stronger than stock. No need to pull the head off, thats overkill.
I read a thread awhile back talking about the blowing plug problem that the for motors had. I had to fix an f250 that I had. You can buy the tap at any auto parts store and tap it out but use the slolid heli's. After you get done you can rig up your vac with a straw and some tape and use it to clean out any shavings left from tapping the hole. It worked for me 7 times. I don't drive the truck anymore but I see it all the time and it's runnin just fine.
