Winter build.....sorta.
I bought a motor off a guy with a GM847 cam, stock crank, Oliver Racing rods and Mahle pistons it's a 355 P&P stock heads, I need injectors and roller rockers with pushrods. It has Comp springs. He took some stuff off for his other build. I've heard it run before he pulled it, it's a very strong motor, it was good for a 10.71 in a Formula through a stalled auto. I need help with injectors rr's and push rods. I will be pulling the old motor sometime this week.. So, any help is greatly appreciated.
10.71 n/a? Unless there's more to this mystery motor, no way. Who did the headwork?
Injectors - take your estimated flywheel HP and multiply it by .07. That gives you a good base for injector requirement.
Rockers - Comp Ultra Pro Magnum, Crane Gold, etc., in the 1.6 variety.
Pushrods - Chromoly one-piece from Trick Flow, Comp, etc., custom length.
Thanks guys, I'll deffinitley look into the Green tops, I'm thinking of doing 383 next time around... Money is tight right now or I'd be doing that now. I just got a killer deal on this engine.
