Fuel Rail Leaking.... HELP!!!
Old 12-21-2010, 11:28 PM
SpeedFreak123's Avatar
Default Fuel Rail Leaking.... HELP!!!
Ok. So now I have got literally everything back together (Head gasket repair)... I turn the key to the "on" position to prime to fuel rails, and fuel starts spraying out of the hose that crosses over the front of the intake that connects the Driver side/passenger side fuel rails?
What is this part called?
Thinking bout buying a new one.
Pic attached
Old 12-21-2010, 11:35 PM
airfix's Avatar
I don't think thats replaceable. You can find fuel rails pretty cheap on ebay and in the forsale section.
Old 12-21-2010, 11:46 PM
hitmanws6's Avatar
just buy a new one off ebay
Old 12-21-2010, 11:51 PM
Originally Posted by RamAir95TA
Maybe the racist in you sabotaged it.
racist in me??
I cant just get that hose??
Old 12-21-2010, 11:54 PM
hitmanws6's Avatar
Nope, our fuel rails are one piece. The rails arent that expensive
Old 12-22-2010, 12:12 AM
The thing is, Then i got to dissconnect my fuel lines, and i cant figure out how too... I have an aftermarket fuel pressure regulator, maybe that has something to do with it
Old 12-22-2010, 12:15 AM
hitmanws6's Avatar
You go to autozone and rent fuel line disconnect tools.....
Old 12-22-2010, 12:16 AM
airfix's Avatar
You'll need a fuel line disconnect tool to remove the fuel lines. You'll need a 3/8 and 5/16 disconnect tool.
Old 12-22-2010, 12:19 AM
airfix's Avatar
It would be easier to just buy them I got 2 nice ones for $8.
Old 12-22-2010, 12:21 AM
Are you guys sure were talking bout the right thing?
I have to buy new rails to fix the leaking hose...
http://www.summitracing.com/parts/EDL-3620/
Those rails dont come with the hose?
Old 12-22-2010, 12:23 AM
airfix's Avatar
Thats because those are the wrong fuel rails for your car.
Old 12-22-2010, 12:25 AM
LOL. that was test
Old 12-22-2010, 12:26 AM
airfix's Avatar
http://cgi.ebay.com/ebaymotors/94-97...Q5fAccessories
Thats what your looking for, there's a few on ebay
Old 12-22-2010, 12:28 AM
My95Z's Avatar
What part of the tube is it coming from?
Their are o-rings on the ends that can be replaced, if they get pinched/bent it will leak.
Old 12-22-2010, 12:29 AM
Yup. Is it worth it to go through the trouble of setting up my Aftermarket regulator and gauge or just list it on the forum for sale?
Old 12-22-2010, 12:30 AM
where the hose enters the front of the drivers side fuel rail.
Old 12-22-2010, 12:33 AM
airfix's Avatar
I would just leave the stock one on there. But keeping the one you have for a spare wouldn't be a bad idea either.
Old 12-22-2010, 12:35 AM
My95Z's Avatar
Then its probably just bent. Pick up a new o-ring and make sure the brackets are square when you put them back on.
Wiggling/forcing the rails and injectors in normally bends one of the brackets that holds the tube on and causes a leak. I had the same issue a while back.
Old 12-22-2010, 12:40 AM
We did have to do some wiggling. Will a o ring for the injectors work? Am I missing a bracket? Can you tell from the pic?
Old 12-22-2010, 12:43 AM
My95Z's Avatar
I can't say for sure, but I do think injector o-rings will fit. I just bought a multi pack at AZ so I can't say for sure.
You aren't missing a bracket, its the rusted thing below the bolt that holds your rail on in your pic. They goes on sideways (4 of them) and hold the tubes to the rails. Just drain the tube of gas and remove the brackets with a torx head. Bend them back to square and reinstall.
Quick Reply: Fuel Rail Leaking.... HELP!!!
