5.3 or 6.0?
5.3 or 6.0?
Hello!
I'm new to the site. I'm looking at 2 engines. I can get a 5.3 w/130kmile with harness for 550.00 or a 6.0 that was in a flood for 500.00. Don't know how bad the flood was or if water got in the engine. Should I chance the 6.0?
Go with the 6.0 you will not regret it even if the water got in the motor take your time and rebuild it these motors are very simple to work on and the payoff can be a lot of usable torque in the range where most of us street car guys like it..
your not going to find a 6.0 that cheap and the price of the rebuild parts is worth the payoff of having a fresh from the bottom up motor forget the intake you probably wont be using it the wiring is useless at that point so you will need a ecu and new harness. than of course you can go carb with a msd or edelbrock controller.
Thanks for the replies! I put a deposit on the 6.0. Found out the motor wasn't completely underwater. They couldn't offer a warranty on it. 6.0 are hard to find under 1k around here!
