1998 vapor canister
1998 vapor canister
My original vapor canister bracket broke off while driving and demolished the canister itself. I bought a used one from Hawks, but now I cant remember how it all goes back together. I have a pic of the canister and the 3 lines that are hanging near the fuel filler neck. Obviously the large hose goes to the large port on the canister, but what about the other two?....One is marked purge and the other is marked tank. The one that says tank has a cap on it....Is that correct...that would leave me with one hose without anywhere to go....
Any suggestions?...or a pic? I couldn't find a diagram of it in the Haynes manual unless i'm not looking good enough
Thank You.
Thank You.
Does anyone have a suggestion on where I can find this information?.....its causing the check engine light to come on and the car is running rough
ok cant find the info with the dealer or the manual
At this point seems like im gonna have to pay for a pic from a member on this site....
Can someone please help?
Never messed with my charcoal canister before, but the purge line should be the one that goes from the charcoal to the intake manifold, drivers side valve cover should have a black solenoid thing that feeds into the intake manifold. The solenoid is feed from one of the two fuel lines.
So go under your hood and find the line I'm talking about, then follow it all the way back to your canister, then you should be fine...
Try this link:
http://www.compnine.com/index.php?u=...03&grouptype=B
It is a diagram layout of the entire 1998 Fuel system.
Hope that gets you going.
