Hot rod impala ss 1964 5.3 swap
Old 12-24-2010, 11:58 PM
rick64ss's Avatar
Default Hot rod impala ss 1964 5.3 swap
I got this 64 impala ss project i am building it on a budget... I bought it with no motor and trans. I am going to do the body work my self and paint.It has some major rust on the floor but not a problem to fix.... i just bought a 2004 5.3 swap with 4L60 trany and ecu....I am going to do the swap my self i need some help!!!! Where to get a web page on how to do the wiring harness...i want to swap the intake to a Corvette or Camaro FUEL RAIL and i think i have to change the throttle body too to a mechanical cable.. What else do i have to change to make it work ?
Old 12-25-2010, 08:13 AM
PRAY HRD's Avatar
Wow that's an adventurous project there man! Good luck with the build!!!
Old 12-25-2010, 08:17 AM
Earl Filter's Avatar
On a tight budget, why not keep the truck intake and drive-by-wire?
Old 12-25-2010, 08:22 AM
Old School Heavy
speedtigger's Avatar
That car needs to be dipped!
Old 12-25-2010, 08:27 AM
crankstart's Avatar
You say not a problem to fix the rust on the floor, WOW. Good luck! But well worth it it in the end.
Old 12-25-2010, 12:06 PM
builder1's Avatar
Cant wait for the progress on this 64. I had one long time ago and still remember it. Good luck on the project, I like it!
Old 12-25-2010, 12:28 PM
rojs234's Avatar
A 2004 5.3 should be a 24X reluctor engine. Go to www.lt1swap.com....he has all the wiring info, complete with pictures to rework your 5.3 Vortec harness yourself. It's really not that difficult. I'm sure glad it's you instead of me starting on that bodywork project, LOL. Good luck! Ron
Old 12-25-2010, 02:31 PM
rick64ss's Avatar
thanks bro any more out their ?
Old 12-25-2010, 03:02 PM
rick64ss's Avatar
has any one ever boght this http://cgi.ebay.com/ebaymotors/LS1-L...Q5fAccessories
Old 12-25-2010, 04:47 PM
Stormed_Norm's Avatar
Well the body work will keep you busy for awhile. NIce looking car, good luck on the project. I have a 62 Biscayne and will be doing a swap in the summer.
Old 12-26-2010, 07:59 PM
rick64ss's Avatar
are you going to so your own wiring ?
Old 12-26-2010, 08:05 PM
MillsMotorvation's Avatar
Well there's a lot of info on here, just start in the sticky section at the top of the pages, good car to restore!
Old 12-26-2010, 11:35 PM
rick64ss's Avatar
Can some one post more links were I can find on how wiring ... Lol
Old 12-27-2010, 11:57 PM
https://ls1tech.com/forums/conversio...chematics.html
might help you out.It's not for the year of engine your using, but at least you can read up abit and gain some knowledge. Where you getting your body parts from?
Old 12-28-2010, 09:30 PM
rick64ss's Avatar
i am getting all the body ports at the pomona swap meet
Old 12-29-2010, 08:56 PM
christla's Avatar
Default 1964
Started on my 2 weeks ago same thing 64 with 2000 5.3 I had to buy f-body oil pan,intake manifold all the front acc.(front pulley wp,alternator bracket ps bracket) heads up get the brackets from dealship cheap i paid 20 for alternator bracket 15 for ps bracket. using standard swap plates for mounts.Moved transmission crossmember back 2in.
Old 12-31-2010, 01:08 AM
sako's Avatar
Im so glad it will be a hot rod impala and not a low rider.
Pomona will be a good place to find a lot of parts. I go there all the time.
All that rust looks scary. Good luck with the build and take a lot of pix.
Quick Reply: Hot rod impala ss 1964 5.3 swap
