questions on ls2 build/swap
ok. I have an 00 t/a. my ls1 is pretty tired and i have money for an upgrade. I want to swap an lq4 into my car. I can pick up a brand new 24tooth lq4 long block for $2350. This is the list of stuff i wanna do with it. Somebody please chime in if you see compatability issues or have better ideas on what i should do. Keep in mind this is a budget swap.
lq4 longblock
fast 102/102 or 92/92 (whatever i can get my hands on for less when i start buyin)
42lb injectors
prc stage 2.5 5.3 heads
the custom grind cam out of my ls1 236/242 .581/.591 114lsa
ls1 harness and pcm
Can i use the lq4 oil pan? do i need any other parts to swap it? What kind of numbers should i be looking at? Any input is greatly appreciated.
lq4 longblock
42lb injectors
ls1 harness and pcm
