Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Leaky Rearend
Old 12-26-2010, 12:14 PM
RENE'S RAGE's Avatar
Default Leaky Rearend
My wife's '98 Vette is leaking grease at the rearend.
I have not jack it up yet to look at it (lazy). I know nothing about this transaxle setup. Is this a self-contained unit? Can I add grease/transmission fluid or what. Hell, I can't even find a trans dip stick. Please help, she's on my ***.
Thanks in advance.
Old 12-26-2010, 06:09 PM
4DRUSH's Avatar
Thanks in advance.
The rear is a self-contained unit (as you call it) and holds around 2 quarts of gear oil. There's no dip stick, just fill it. The fill plug is on the rear right hand side. It's hard to fill, you would be better off having it filled at Jiffy Lube.
The left (driver's side) cover on the rear is most likey your problem. It needs to be removed & sealed with RVC Silicone.
(and replace the axle seal)
Old 12-26-2010, 06:34 PM
Thanks, I'll send it to the dealership and they can fill it.
What about the transmission, does it have regular trans fluid in it or is it self-sealed. Does it have a dip stick.
Old 12-26-2010, 08:19 PM
TooMuchMoney's Avatar
I know a guy that can get you brand new CV Axles for $25.00 from DFW Texas if you need a new one!
Old 12-26-2010, 11:41 PM
4DRUSH's Avatar
Here, I did a search for you. BTW- no dipstick in trans either
http://mysite.verizon.net/res0aae8/diff.html
http://mysite.verizon.net/res0aae8/tranny.html
P.S.- You should look for a Corvette shop in your area instead of the stealership.
Old 12-27-2010, 05:52 PM
Thank you sir, for the search. I'll probaly be doing the work myself.
Quick Reply: Leaky Rearend
